It is currently Mon Sep 15, 2025 9:06 am
 Post subject: Truss Notch Cutter
PostPosted: Sun Apr 30, 2023 4:06 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
https://www.stewmac.com/luthier-tools-a ... gK33vD_BwE
Great tool. But I wish it had a smaller cutter. Thoughts? Something more suitable for smaller pegheads (mandolins?) Can I get a smaller version of that cutter?
 Post subject: Re: Truss Notch Cutter
PostPosted: Sun Apr 30, 2023 4:12 pm
McMaster-Carr has them.
PostPosted: Mon May 01, 2023 9:06 am
You could use a W.L. Fuller four flute countersink and chisel the taper flat to give a square shoulder. Find a countersink without the set screw collar such as this type (or file off the collar of those that have it):
https://hardwickandsons.com/products/w- ... ag_organic
PostPosted: Mon May 01, 2023 11:25 am
That is a really cool hardware store Clay. They have good prices and some hard to find tools.
PostPosted: Mon May 01, 2023 1:20 pm
City: U.P.
Look for counterbore's or type R counterbores.
Brian R, Wood Mechanic
N8ZED
PostPosted: Mon May 01, 2023 2:09 pm
Hi Barry,
That is an interesting store - thanks for pointing that out.
Brian - I should have looked a little farther. They do have counterbores - a few more bucks, but not too expensive:
https://hardwickandsons.com/collections ... ounterbore
These users thanked the author Clay S. for the post: Pmaj7 (Tue May 02, 2023 8:18 am)
PostPosted: Tue May 02, 2023 7:53 am
First name: gary
Last Name: davis
City: BILLINGS
State: Montana
Zip/Postal Code: 59105
Only a ten-hour drive for me to the store but its right on my route from home to the boat moored in Bellingham. Definitely checking it out next time through.
PostPosted: Tue May 02, 2023 10:03 am
City: U.P.
Here is a smaller one - https://www.jamestowndistributors.com/product/product-detail/500
Jamestown used to have several different sizes, and I've ordered some from them before.
N8ZED
These users thanked the author rbuddy for the post: Pmaj7 (Tue May 02, 2023 10:42 pm)
PostPosted: Tue May 02, 2023 5:43 pm
First name: Mark
City: Seattle
Yeah, Hardwicks is great. It was a sad day when they moved out of Seattle (sad for me, not necessarily sad for them).
PostPosted: Fri May 05, 2023 2:41 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Just asking, are any of these compatible with the stew-mac system? The rod diameter is my concern (and locking in to it). Nice if someone here has done that...
PostPosted: Fri May 05, 2023 4:44 pm
First name: Dan
Last Name: Miller
City: Cape Vincent
Zip/Postal Code: 13618
If it doesn't fit the SM shaft, you could just get some drill rod of the appropriate diameter to fit the counterbore.
PostPosted: Fri May 05, 2023 6:40 pm
The counterbores list the diameter of the center hole. You can use an extra long drill bit chucked into drill backwards or a drill rod as mentioned. Such as:
https://www.amazon.com/COMOWARE-Long-Dr ... WV1OIITOXD
Users browsing this forum: Michaeldc and 54 guests
